1995 Isuzu Rodeo Question o2 sensor
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
CMSHOUGH
Got a 1995 rodeo blowing black smoke out the exhaust. Changed the plugs. Next was going to try the o2 sensor to see if that eliminated the problem. Does that sound about right or maybe the plug wires?
Mar 30, 2010 at 12:52 PM
DOCFIXIT
  • 18,828 POSTS
Maybe faulty Engine Coolant Temp sensor located rear engine in coolant manifold. OHM check cold @34000 ohms then let engine warm OHMS should drop. If not replaceECT
Mar 31, 2010 at 8:06 AM
