1995 Isuzu Rodeo Question no power to fuel pump
SCUBAJAY
Engine Mechanical problem
1995 Isuzu Rodeo Question 6 cyl Automatic 85,000 miles
I am not getting power to the fule pum. I tested at the plug near the pump with no power. I also have tested for power at the fuel pump fuse and relay and I'm getting power at each one.
Jan 12, 2009 at 2:51 PM
  • 75,988 POSTS
Check the pink and white wire pin 5 on the fuel pump relay wiring connector for power when key at run position-do you have it?
https://images.2carpros.com/forum/automotive_pictures/12900_fp_relay_6.jpg
Jan 12, 2009 at 11:25 PM
