1995 Isuzu Rodeo Question Knocking noise
1995 ISUZU RODEO
TACOWALLACE
Noises problem
1995 Isuzu Rodeo Question 6 cyl Two Wheel Drive Automatic
I just recently began to hear a knocking noise coming from below the engine. I was told previously that it may be a bad valve somewhere, or a PCV valve needs to be replaced. The noise is pretty loud, you can't hear it well inside the car, but outside it can be heard well. I've also noticed a slight hesitation in gear switching.
Jun 11, 2008 at 7:30 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi TacoWallace,
If the noise is from the lower end of the engine, it cannot be the valves.
If the noise increases in level when revving the engine quickly, then most probably it is the con rod bearings.
Jun 15, 2008 at 8:05 AM
