1995 Isuzu Rodeo Question Engine stalls
J. HOLLAR
  • 1995 ISUZU RODEO
  • 4 CYL
  • MANUAL
  • 141,000 MILES
Just replaced my head gasket, and think I got everything back togrther right. Car starts OK, but stalls as soon as I stop pumping the gas. Maybe I got a vacuum line hooked up wrong?
Monday, April 5th, 2010 AT 2:51 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,756 POSTS
It sounds like the EGR valve could be engaged while the engine is at idle, Please disconnect the vacuum line to the EGR and retest. Get back to me with the results so we can continue. Thanks for using 2carpros. Com
Wednesday, April 7th, 2010 AT 4:02 PM
Hi J. Hollar, Welcome to 2carpros and TY for the donation
Did you put engine no.1 piston on its compression stroke/TDC and line the camshaft and crankshaft markings as specified and the timing indicator on the pulley on TDC/0 and rotor pointing to the no.1 cap tower? Valve and Ignition timing could be still off
Try cleaning out the idle air control valve and test the throttle position sensor and clean out the MAF with an approved cleaner and also clean out the EGR valve.
Wednesday, April 7th, 2010 AT 4:12 PM
