Rr anti-lock and brake light on dashboard will not go off.Is this a sensor problem, or is it supposed to stay on .
Jan 18, 2008 at 2:44 PM
LALORENZO
MEMBER
Yes, there is definitley a sensor on the rear rotors, if it is damaged, worn or broken the light will stay on. Inspect the electrical wire going to your rear rotors (there is only one per side). Look for obvious damage. I nothing noticable, go to your dealer. This problem should not be delayed, these are your BRAKES!!!
Feb 12, 2008 at 4:27 PM
