1995 Isuzu Rodeo Question
1995 ISUZU RODEO
178,546 MILES • 6 CYL • 4WD • AUTOMATIC
FRAMER
i HAVE REPLACED ALTERNATOR AND BATTERY AND WHILE DRIVING THE VOLTAGE DROPS TO ZERO , HOWEVER AR STOP LIGHT CAR RPMS STAY AT NORMAL IDLE. BATTERY IS DRAINED TOTALLY AFTER EACH USE WHAT COULD BE CAUSING THIS
Jun 17, 2008 at 12:19 PM
  • 31,937 POSTS
Hi there,
You will have to have a currant draw test done on the electrical system. To do this place a Amp meter between Bat Pos & Bat Pos cable (don't try and start engine) this will show any currant draw, with doors closed & key off. If above .25 Amp start pulling fuses to locate the problem circuit.
Mark (mhpautos)
Jun 17, 2008 at 12:37 PM
