I'm wondering how to adjust the timing on my rodeo. What parts control timing? any tips on getting one to start
Jan 17, 2009 at 8:05 PM
DOITYOURESELF
MEMBER
turning the distributor adjusts the timing, if it wont start, check out to see if its getting spark first before you mess with timing. If not check and replace ignition wires, plugs, cap and button. Then check to see if you are getting fuel. putting a 1/2oz shot of fuel in intake should make it run for 3-4 seconds. if it doesnt check fuses, relays, fuel filter, fuel pump.
