1994 Isuzu Rodeo Question temp. gauge
125,879 MILES • 6 CYL • 4WD • AUTOMATIC
JADATT47
I've replaced the 2 tempsending units, my temp. gauge on the dash goes to hot when I turn on the key and stays there after the car is started, never moves
Sep 1, 2010 at 1:17 AM
DOCFIXIT
  • 18,828 POSTS
Wiring problem unhook at sender and gague OHM chek to ground if you get continuity then wire is shorted to ground
Sep 1, 2010 at 4:14 AM
