I replaced the ignition Modual, and the Coils, Still no Spark, I have checked all the fuses, and Relays, they all are good. What is the most liklely device to be not allowing power to the coils?
The two wire plug on the Right hand has 12 Volts to it, But when cranking none of the pins on either Left hand plujg show any voltage. I suspect some sensor is out, but where?
Jul 26, 2010 at 3:32 AM
