1994 Isuzu Rodeo Question Fuel pump relay switch
BUTT3RFLY_KISS3S
Engine Performance problem
1994 Isuzu Rodeo Question 6 cyl Four Wheel Drive Manual
Where is the fuel pump relay switch located at on a 1994 Isuzu Rodeo? Pump kicks in if wire is attatched to it and battery, but not if you turn it by the ignition switch.
Jan 24, 2010 at 3:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
fuel pump relay is located on the fuse / relay block, on right side of engine compartment.
Jan 24, 2010 at 4:04 PM
