1994 Isuzu Rodeo Question Clutch line leaking
SCOUTT800
Transmission problem
1994 Isuzu Rodeo Question 6 cyl Four Wheel Drive Manual
We purchased this vehicle 2 mo ago AS IS NO WARRANTY. When driving our 1994 Isuzu there is no pressure when depressing the Clutch pedal. This came on suddenly. Today my husband noticed the clutch line is broken as there is fluid leaking in on the floor board. My husband hasn't replaced a clutch before, but has done breaks, etc. What does or may need to be replaced in addition to the line? What else might we run into? Any help/suggestions you can provide would be much appreciated.
Thanks!
Apr 7, 2009 at 4:35 AM
  • 31,937 POSTS
HI there,
Start with replacing the faulty line and re bleed the clutch, check the master cylinder & slave cylinder for leaking seals and if so replace as well, start here.
Mark (mhpautos)
Apr 7, 2009 at 10:11 AM
