1993 Isuzu Rodeo Question Put new fuel pump in and still isn
170,000 MILES • 6 CYL • 4WD • MANUAL
KCSAMUELS
We just put a new fuel pump in and it still is not running. What should we check and where is the fuel pressure regulator?
Mar 16, 2009 at 1:52 AM
  • 75,988 POSTS
Do below to determine if its fuel or spark problem
Mar 16, 2009 at 1:55 AM
  • 75,988 POSTS
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 16, 2009 at 1:58 AM
