I put everything back together the truck doesn't start any more?
BLACKKHMER
  • 1993 ISUZU RODEO
I change my water pump on my 93 rodeo and I moved the crank pulley just little bit and now after I put everything back together the truck doesn't start any more. So can you guys help me?
Tuesday, December 15th, 2009 AT 12:08 AM
  • 31,937 POSTS
Hi there, let me know if the valve timing is correct now and how far the crank moved. Have you checked all electrical connections you undid? Run a scan if you can and check any unresolved fault codes, start here.
Mark (mhpautos)
Friday, January 3rd, 2020 AT 4:30 PM
BLACKKHMER
I don't kno how I moved it I just did on accident because I was tring to read a book on how to replace a water pump and moved the crank pulley on accident so now I have water pump out and put the new one in already so I go to see if my truck would start before I put everything else back and it didn't start I didn't take any electrical out or any thing. Now what do you think I should do? Do you have any ideas or suggestion to go about this problem of my?
  • 31,937 POSTS
You have checked that the valve timing is correct? Do you have spark? Do you have fuel pressure? Do you have injection pulse? Check all these and have a scan done as well, we must know if there is any unresolved fault codes to deal with, you do not always have a check light with all codes.
Mark
