i put everything back together the truck doesn't start any more?
BLACKKHMER
i change my water pump on my 93 rodeo and i moved the crank pulley just little bit and now after i put everything back together the truck doesn't start any more. So can you guys help me?
Dec 14, 2009 at 4:08 PM
  • 31,937 POSTS
Hi there, let me know if the valve timing is correct now and how far the crank moved. have you checked all electrical connections you undid? run a scan if you can and check any unresolved fault codes, start here.
mark (mhpautos)
Jan 3, 2020 at 8:30 AM
BLACKKHMER
i don't kno how i moved it i just did on accident because i was tring to read a book on how to replace a water pump and moved the crank pulley on accident so now i have water pump out and put the new one in already so i go to see if my truck would start before i put everything else back and it didn't start i didn't take any electrical out or any thing. now what do you think i should do? do you have any ideas or suggestion to go about this problem of my?
  • 31,937 POSTS
You have checked that the valve timing is correct? do you have spark? do you have fuel pressure? do you have injection pulse? check all these and have a scan done as well, we must know if there is any unresolved fault codes to deal with, you do not always have a check light with all codes.
Mark
