1992 Isuzu Rodeo Question speedometer
1992 ISUZU RODEO
143,957 MILES • 6 CYL • 2WD • AUTOMATIC
FREEGAMEPASS
got the truck from a buddy of mine he said the speedometer use to work,hassnt worked since ive owned it put in new cable still no luck,tech works fine,but cant get the speed to work any sujestions
Jul 20, 2008 at 8:09 PM
2CARPRO JACK
  • 11,533 POSTS
Need to pull the cable out of the speedo and watch it while driving to see if it turns. If it does the problem is in the speedo head, if not turning, the speedo drive in the trans is most likely the problem
Jul 21, 2008 at 12:50 AM
