1992 Isuzu Rodeo Question Low oil Pressure
1992 ISUZU RODEO
115,000 MILES • 6 CYL • 4WD • AUTOMATIC
AREBOJA
I have 1992 Isuzu Rodeo, 4WD,6 cylinder automatic and carburator.
During start up oil pressure is excellent. Running in freeway oil pressure is good but once the engine is in
idle oil pressure is getting low at 15 psi to zero.
I changed my oil and filter and I noticed that my oil filter is dry it seems the oil by passed the oil filter.
I need some info if I need engine rebuild or my main bearing is worn out.
Thanks,
Alex R.
Jan 30, 2010 at 4:15 PM
Check the oil pressure with a mechanical gauge this will tell you something.
A plugged oil filter can be yet another cause of low oil pressure. When the oil leaves the pump, it passes through the filter before going on to the bearings and oil galleys. All filters create a certain amount of resistance to flow that increases with the rate of flow. But the amount is not much, typically only a couple of pounds. But as the filter becomes clogged with debris, the restriction created increases. Eventually the point may be reached where no oil will pass through the filter element. So to prevent such a blockage, a pressure relief valve located in the filter or where the filter mounts to the block is designed to open if the pressure differential across the filter exceeds a preset value (typically 5 to 40 psi). This allows the oil to bypass the filter and keep on flowing. But the engine's oil pressure will be reduced to that of the bypass valve. Replacing the plugged filter will solve the problem.
Jan 30, 2010 at 4:21 PM
