1992 Isuzu Rodeo Question Compression
DJ HANEY
Engine Mechanical problem
1992 Isuzu Rodeo Question 6 cyl Four Wheel Drive Manual
I have a rodeo that will turn over but wont start its been sitting for a while and it use to run I changed the plugs and made sure its getting fuel but now the compression is low its getting anywhere from 35-65 pounds of pressure in the cylenders what could I do to bring it back up
May 9, 2008 at 4:17 PM
  • 75,988 POSTS
Those pressures are way too low-What happened
Put a tablespoon of 30 weight oil in each cylinder and crank engine over a few times -put sparkplugs back in and attempt to start it-No start check the timing belt/chain.
May 9, 2008 at 4:29 PM
