1991 Isuzu Rodeo Question clutch issues
150,000 MILES • 6 CYL • 4WD • MANUAL
GAONEAL02
trying figure out how in the world to bleed my clutch on a 1991 Rodeo. I replaced the slave cylinder, tried bleeding it at the slave cylinder and the intermediate bleeder valve on the side wall of the engine compartment, by opening the slave cylinder bleed valve, depressing clutch pedal, closing bleeder valve, pulling the clutch pedal back up. After doing this 400-500 times, no progress. I bought a vacuum/bleed system and hooked it up to the slave cylinder bleed valve and while system was fully closed, pumed up the vacuum, then opened the blleder slowly. After several times doing this, no results but a tired hand. Anybody have suggestions please? This has baffled me as to how hard this is. Thanks!
Oct 12, 2010 at 7:30 AM
DOCFIXIT
  • 18,828 POSTS
Try this attach clear tube to slave bleeder other end in container with fluid. Open bleeder have assistant push pedal down close bleeder repeat until no more air bubbles
Oct 12, 2010 at 7:45 AM
GAONEAL02
"Try this attach clear tube to slave bleeder other end in container with fluid. Open bleeder have assistant push pedal down close bleeder repeat until no more air bubbles"
I am not understanding this at all. Can you please bring more clarity?
Oct 12, 2010 at 8:03 AM
