1991 Isuzu Rodeo Question clunks when cold.
350,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAMESDENNIS
My 91 isuzu rodeo idles high (1000 rpm) and clunks when coming to a stop (ie when gearing down) for about the first 15 minutes of driving time. Once I have a few miles on it, it seems to run fine. Had the trans serviced, they could find nothing wrong and the problem disappeared. Showed up a again about 3 months later. Took it to the shop they found some shorted wires. Problem disappeared for a couple of months and is back again.
Oct 12, 2010 at 2:07 PM
KHLOW2008
  • 41,812 POSTS
Hi JamesDennis,
Was any atempt made to retrieve for trouble codes?
Oct 13, 2010 at 7:50 AM
JAMESDENNIS
[quote:ea77e9635f="JamesDennis"]Engine Mechanical problem
1991 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 350000 miles
My 91 isuzu rodeo idles high (1000 rpm) and clunks when coming to a stop (ie when gearing down) for about the first 15 minutes of driving time. Once I have a few miles on it, it seems to run fine. Had the trans serviced, they could find nothing wrong and the problem disappeared. Showed up a again about 3 months later. Took it to the shop they found some shorted wires. Problem disappeared for a couple of months and is back again.[/quote:ea77e9635f]
When the Trans shop serviced the trans, they first hooked it up and said everything came up fine (which they said sur[prised them considering there apparently is an inordinatel amount of electronics on the 91 Rodeo)
Oct 13, 2010 at 11:56 AM
KHLOW2008
  • 41,812 POSTS
Under such circumstances, you would have to hook up diagnostic equipments and go for a test drive. Note the data stream when problem occurs and check if any is out of spcec.
Oct 13, 2010 at 11:44 PM
