Oil Pressure in 98 Isuzu Trooper 3.5L 6Cyl, 96K~ mileage
1998 ISUZU
MATTRM
I am having strange oil pressure issues with my trooper. When the engine is cold my pressure is great, then after about 20 miles of driving, the pressure drops, sometimes to zero when I come to a stop, but comes up while driving. I check oil, and I have oil on the Full mark on dipstick. This is greatly affecting my Gas Mileage.
One person suggested cam bearing issue, another, oil lifter (?). Jiffy lube puts in High Mileage Enging oil but does not seem to help the issue. Another suggestion was using 20/50 Oil instead of 10/30. Help!!
May 6, 2007 at 10:14 AM
MRTRDRVR
  • 20 POSTS
First thing I would do is attach a manual oil pressure gauge to where the oil pressure sending unit screws into.That way you could verify that you don't just have a bad sending unit or faulty gauge.
If in fact it is the true pressure then I'd wager your getting ready to spin a rod bearing. Mine did that at 98,500.
Playing with the viscosity of the oil will probably raise your gauge readings but ultimately due more damage to your engine.
Good Luck
Dale
May 7, 2007 at 3:41 PM
RANDOMORBIT3
  • 9 POSTS
You will find that your engine will need a overhaul. You said oil pressure is good when cold. If it is below 75 at a idle cold and 35 on a fully warmed engine then you are looking at a melt down. Very possible the oil pump is going up and again overhaul will be necessary because if you are going to do all of that work you might as well do the rest because it will not be long. After repairs are done change your oil and filter every 2 moths and or 2000 miles or so. I know what they recommend but for most drivers 3 months or 3000 miles is too long. And most people get rid of their cars after 2-3 years and then it is another owners problem. These engines run hotter and not like older cars of days gone by.
Fred
May 29, 2007 at 10:28 AM
