1993 Isuzu Trooper Pulley Bolt Removal Fix
ISUZU
HELIRAF
Isuzu Trooper, 1993, 130,000 miles. I'll be needing to take off the pulley, as I'm going to be changing the head gaskets, but I can't figure out how to lock the crankshaft in order to undo the pulley bolt, and then later to instal and torque it. I think there might be an Isuzu part available for this, but can't get hold of it anywhere. Can anyone help?
May 18, 2006 at 9:09 AM
LOSONE
  • 1,616 POSTS
I don't know the exact belt set-up but us old gray haired mechanics leave on the belt, tighten it good and clamp 2 pieces of wood on the belt where it will bind again anything that will hold.
Use an impact wrench and off comes the bolt.
You will probably need a puller to pull the pully from the shaft. I have a universal Snap On that does the trick. You can probably rent one to do the job.
Maybe you will be lucky and tap the back of the pully on oposite sides with a wood block and it will slide right off.
Good Luck
May 18, 2006 at 9:30 AM
Suggested Repair
Leave the drive belt installed and tighten it, then clamp two pieces of wood on the belt so it binds against something solid. Use an impact wrench to remove the crank pulley bolt. Rent or use a pulley puller if needed; tapping opposite sides of the pulley with a wood block may also free it.
Conversation Summary
The owner of a 1993 Isuzu Trooper needs to remove and later torque the crankshaft pulley bolt while changing head gaskets but cannot lock the crankshaft and cannot obtain a special Isuzu tool. The expert suggested tightening the belt, clamping wood so the belt binds, and using an impact wrench, then using a puller or careful tapping to remove the pulley.
