It's cold and I have no heat!
ISUZU
UTDREA
I have a 2001 Isuzu Rodeo with about 67K miles on it. I have what is evidently a typical problem with the blower motor - it just quit on me completely. I checked the fuses, and that isn't the problem. I am trying to determine the location of the relay for the blower motor, to see if this is the issue, and can't find this information in my manual. Any ideas? Thanks!
Dec 8, 2006 at 12:42 AM
BACKYARDMECHANIC
  • 337 POSTS
I don't know where the relay is but you should check to see if you have power to the blower motor first. The blower motor could be bad. Remove the plug from the blower motor and connect a 12 volt test lamp to the wire. If the lamp lights then the fuse and the relay are good and the motor is bad. Good Luck :)
Dec 8, 2006 at 8:04 AM
