1999 Holden Jackaroo High Idle Surge
ISUZU
DUSTINS
Hello I dont know if you can help i live in australia and i am trying fix a holden jackaroo 1999(isuzu trooper?) model with a 3.0 litre diesel motor (4JX1). In the mornings after driving for about a minute the car surges and the car revs high. It will actually take off of its own accord if the clutch is out. The injectors had a recall for that model and they have been replaced. When i plug in a scan tool fault codes P0198 Engine oil temperature sensor high and P0380 glow plug/heater circuit a malfunction comes up. Would these fault codes cause that problem? If not do you have any ideas what might? If you a can help I would be happy to provide a donation.:)
Cheers
Dustin
Sep 5, 2007 at 12:01 PM
  • 31,937 POSTS
G'Day there,
The codes that you have won't cause the problem you have normally. Out of interest do you know what oil is being used, it should have (in Mobil) Mobil 1 10W-30. I fell that the problem is in the injector pump / governor. Email me at mhpautos@bigpond.com and i will do some home work on it for you.
Mark (mhpautos) Traralgon Vic,
Sep 5, 2007 at 6:01 PM
Suggested Repair
The stored codes normally would not cause the surge. Confirm the correct engine oil is used (Mobil 1 10W-30 was specified) and have the injector pump and governor diagnosed.
Conversation Summary
The owner of a 1999 Holden Jackaroo, also identified as an Isuzu Trooper, with a 3.0 diesel reports that the engine surges and revs high after about a minute in the morning and can move the vehicle if the clutch is out. The injectors were already replaced under a recall, and codes P0198 and P0380 are present. The expert says those codes normally would not cause this behavior, asks whether the specified oil is being used, and suspects the injector pump or governor.
