95 Isuzu Rodeo 3.2 harmonic balancer question!
1995 ISUZU
CONFEDEREDNECK
Howdy folks, Stu here! I'm a newbie to the forums but have noticed there seems to be a lot of knowledge here! Anyhow my question is on my wifes 1995 1/2 Rodeo 3.2 sohc v6. The hormonic balancer is shot on it so I've got it all torn down (radiator and ect) to the balancer/pully assembly but cant get the crank bolt broke loose with my 1/2" ratchet! I understand it to be torqued at 123 lbs so I know it's tight but I wnat to make sure it isnt some backward thread type thing before I put my impact gun on it! Thanx for any help and info, Stu
Dec 16, 2006 at 10:33 AM
CARUNDELL
  • 602 POSTS
[quote:9aab613c6d="confederedneck"]Howdy folks, Stu here! I'm a newbie to the forums but have noticed there seems to be a lot of knowledge here! Anyhow my question is on my wifes 1995 1/2 Rodeo 3.2 sohc v6. The hormonic balancer is shot on it so I've got it all torn down (radiator and ect) to the balancer/pully assembly but cant get the crank bolt broke loose with my 1/2" ratchet! I understand it to be torqued at 123 lbs so I know it's tight but I wnat to make sure it isnt some backward thread type thing before I put my impact gun on it! Thanx for any help and info, Stu[/quote:9aab613c6d]
Yo Redneck!! (lol)
"gun " away bro!!
Chris
P.S. Ya got nothin' to worry about and re-torque to spec when you are done! And a 'lil bit of thread locker won't hurt either!
Dec 16, 2006 at 10:40 AM
CONFEDEREDNECK
Thanx for the info my friend! I'll go out there and rattle it off tomorrow then! Part aint gunna be here till Monday but just tryin to get a jump on the repair! These are some great forums, glad I ran across em! Thanx again Chris!
Stu
Dec 16, 2006 at 11:00 AM
CARUNDELL
  • 602 POSTS
[quote:2fe7ed0135="confederedneck"]Thanx for the info my friend! I'll go out there and rattle it off tomorrow then! Part aint gunna be here till Monday but just tryin to get a jump on the repair! These are some great forums, glad I ran across em! Thanx again Chris!
Stu[/quote:2fe7ed0135]
Hey Stu,
My pleasure and glad to help! spread the word, the more the merrier!
Chris
Dec 16, 2006 at 7:53 PM
2CARPRO JACK
  • 11,533 POSTS
Dont get discouraged if your gun isnt strong enough to remove the bolt.Seen the bolts lock themselves in enough to require a little heat on the bolt to get it loose. Just something to keep in mind
Dec 17, 2006 at 12:24 AM
CONFEDEREDNECK
Thanx again yall! Busted one impact socket but got it off! I think gettin the balancer off the crank was the hardest part, the bolt on my puller wasnt long enough so I had to make a tool and finally got it off! Again thanx for the help yall! 8)
Dec 17, 2006 at 1:17 PM
RODEOAHOLIC
So, how did you get that nut off of that Rodeo crankpulley?? Was it reversed threads or not? I am in the same situation questioning wether it comes off to the right /clockwise or to the left/ counter. Which is it?? If you could please let me know cause, the manual don't say jack!!
Jan 29, 2007 at 5:58 AM
