92 Isuzu PU 2.6L AT
History:
Engine had bad piston, I decided to buy a used engine that had 87k miles on it. Got it for a good deal. Ordered it, got it in, Would not start. Replaced fuel pump when fuel was not getting to the engine.
Fine.
Issue:
It will not start. When we spray ether in it, it fires up for a second (literally) but does not stay running. It appears to burn off the excess ether in the engine. We are getting fire and gas going THROUGH the Fuel Injector tree and back to the return line to the tank.
Question:
Are the injectors spraying the gas? If not, is there a way to clean them without replacing them? If so, should I spend the money on trying to rebuild the injectors (new seals and cushion gaskets) which cost about $80 or should I replace every injector which is $80 a piece?
Are the injectors the problem at all? All fuses, relays check out.. I do not have a computer code checker to check the codes but it ran before I took the engine out....
*REVISION* the engine I bought did not have alot of the electronic sensors/modules etc, all of them came off the OLD engine*****
History:
Fine.
Issue:
Question:
Mar 15, 2007 at 11:12 AM
