I have a 2001 Isuzu Rodeo (4WD) w/ 80200 miles. The check engine light came on and I was told that it was the EGR valve that needed replaced. It has since been replaced and the hosing cleaned and the check engine light keeps coming back on. As far as I'm concerned that is not the problem. I have trouble starting the car and when it does start it revs really low and will rev up and down until I start driving. A lot of the times it won't start right away and I have to push the gas pedal to get it started. Also, sometimes after it has started it will just die. I have had one instance where I came to a stop sign and it died, thankfully it hasn't happened again. And one time it wouldn't go about 30, no matter what I did. I had to pull over, turn the car off and restart it and it was fine. I could really use some help on this one. Thanks!
May 15, 2007 at 9:39 PM
