2000 Other Isuzu Models HEATER CORE HOSES STAYING HOT
2000 ISUZU
162,000 MILES • V8 • 2WD • AUTOMATIC
MCAUTODOC
  • 33 POSTS
VIN #4KLC4B1R6YJ805937 / 2000 Isuzu NPR delivery truck.
Did some a/c work and noticed the hoses going to the heater core were the same temp ( approx. 155 deg) with the dash valve set all the way to cold and in recirculation mode. I identified the hose coming out of the water pump as the supply to the core and clamped it off; within a couple min the temps had come down to around 95-100 deg on both hoses and decreased the a/c vent temp a couple degrees. Anyone have a diagram showing the vent/dash controls for the HVAC system on this truck? Would like to have something to check out before I go taking the dash off to see what the problem is.
Aug 21, 2009 at 8:17 PM
MERLIN2021
  • 17,250 POSTS
Sorry I don't have any diagrams for it, but if the A/C compressor is working, and charge is full, the temperature blend door is binding or the actuator /cable to it is defective, heater hoses should be hot! Heat is turned off by the temp blend door for a/c! This is inside the heater plenum assy.
Aug 21, 2009 at 11:27 PM
