1998 Isuzu Trooper - Loud Grinding/Spinning Metal noise
1998 ISUZU
BOBRULES5
My 1998 Isuzu Trooper with 99,000 miles recently started making a loud metal on metal noise. It sounds like a someting spinning. It does not get louder or softer by acceleraton, but start loud and quiets a bit after a few seconds. Then as I drive a few minutes the noise seems to get louder.
I took it to a local repair shop hoping for the best and semi prepared for more. Much to my surprise they were able to find many things wrong.
Here is what I was told is wrong. The cause of the noise is the Air Conditioning compressor and all that comes with that. They said that since Isuzu runs on 1 belt?, it is important to repair. Cost $1389.00 w/labor. Then the water pump. Has a small leak. 680 w/labor. Then the rear calipars are locked (news to me) $1100.00 (pads rear and bac, which by the way both replaced in last 15 months). You see where I'm headed. 98 trooper - $3000 in repairs, I'm not sure it's worth it. The problem is i still owe a couple grand on the care and can't scrap it. I'm looking for advice. I plan on getting some sort of second opinion. Not so much because I don't believe them as much as i need a fix for cheaper! Any ideas???
J
Apr 13, 2006 at 1:29 PM
LOSONE
  • 1,616 POSTS
A lot of those repairs can be made with used parts. It doesn't take a brain surgeon to fix brakes and replace some of the other items. The compressor is easy to replace you have to have it charged. A lot of people get "upside down" in vehicles but it sounds like yours is worth saving with used parts. Good luck
Apr 14, 2006 at 3:40 AM
