1997 Other Isuzu Models
1997 ISUZU
GOOBER141
Electrical problem
1997 Other Isuzu Models 4 cyl Two Wheel Drive Manual 118k miles
hi. I thank you in advance for any info.i was coming home from work when my truck just died AAA pulled it home for me.i figuered battery so i took it to autozone and it tested good so i stuck it back in and viola the under hood light came on.I tried starting it and turned over a few times then nothing.battery still good just no voltage anywhere no dome light etc.I would appreciat e any help you can provide.
Respectfully submitted;
john
P.S. battery cables are clean as well as grounds
Aug 28, 2008 at 1:33 PM
  • 31,937 POSTS
Hi there,
If you are getting an interrupted power supply, simple things first, service the battery terminals and check the earth's and power supply's for a good connection.
Mark (mhpautos)
Aug 28, 2008 at 1:39 PM
GOOBER141
cables are good and i cleaned all grounds
thanks
john
Aug 28, 2008 at 1:47 PM
