1995 Isuzu Lets set the story strait
1995 ISUZU
BUHDHASAC
Engine problem
1995 Isuzu V6 Two Wheel Drive Automatic 100000 miles
Ive read that the numbers on oil, 30/50 weight, mean that the oil is thiner when cold and thicker when hot,or running temp. But you said in here that it dont matter that oil gets thiner when getting hotter, how can this be both? Not angry or anything just wonder what is truely the truth! Peace! let us all know what you think
Dec 9, 2007 at 4:50 AM
Below will make you understand something about oil vicosity-meaning how easy the oil will flow thru the lubrication system.
The higher the vicosity number the thicker the oil and vice versus-
Most vehicle manufacturers today specify 5W-30 or 10W-30 motor oil for year-round driving. Some also specify 5W-20. Always refer to the vehicle owners manual for specific oil viscosity recommendations, or markings on the oil filler cap or dipstick.
As a rule, overhead cam (OHC) engines typically require thinner oils such as 5W-30 or 5W-20 to speed lubrication of the overhead cam(s) and valve-train when the engine is first started. Pushrod engines, by comparison, can use either 5W-30, 10W-30 or 10W-40.
As mileage adds up and internal engine wear increases bearing clearances, it may be wise to switch to a slightly higher viscosity rating to prolong engine life, reduce noise and oil consumption. For example, if an engine originally factory-filled with 5W-30 now has 90,000 miles on it, switching to a 10W-30 oil may provide better lubrication and protection. The thicker oil will maintain the strength of the oil film in the bearings better so the engine will have more oil pressure. This will also reduce engine noise and reduced bearing fatigue (which can lead to bearing failure in high mileage engines).
For sustained high temperature, high load operation, an even heavier oil may be used in some situations. Some racing engines use 20W-50, but this would only be recommended for an engine with increased bearing clearances. Increasing the viscosity of the oil also increases drag and friction, which can sap horsepower from the crankshaft. That's why 20W-50 racing oil would not be the best choice for everyday driving or cold weather operation for most vehicles. The latest trend in racing is to run tighter bearing clearances and use thinner oils such as 5W-30 or 5W-20 to reduce friction and drag.
Dec 9, 2007 at 5:42 AM
