1994 Other Isuzu Models hydrolic clutch
1994 ISUZU
68,000 MILES • 6 CYL • 2WD • MANUAL
MADDNESS
iv replaced the master and slave unit on the clutch iv bled it 10 times the pedal works fine for a few days then starts slowlys going down iv check for leaks theres none what could cause this
Oct 3, 2008 at 5:13 AM
DOCFIXIT
  • 18,828 POSTS
I assume when you rebleed it is O.K. If so try this put a clear plastic tube on bleeder place into a contanier of fluid. Open bleeder have someone pump pedal, until no more bubbles. Keep eye on master fluid level.
Oct 10, 2008 at 5:49 AM
