1993 Other Isuzu Models Window off track
1993 ISUZU
VKNOLL
Interior problem
1993 Other Isuzu Models Two Wheel Drive Manual
How do I put the window back on track? I have the cover plate off, but I cant put the front side on it's track.
May 26, 2008 at 4:20 AM
KHLOW2008
  • 41,814 POSTS
Hi Vknoll,
You need to remove the door glass mounting points and slant the glass into the slots. Reinstall after mounting points.
Ensure that the regulator base is not bent and you might need to realign it by adjustment. A hardened glass run channel will cause tilting of door glass when going up.
May 31, 2008 at 6:19 PM
