1993 Other Isuzu Models turn signals
1993 ISUZU
167,000 MILES • 4 CYL • 2WD • MANUAL
BENKREPP
i bought this truck and two weeks later the turn signals quit working. the emerdency flashers still work but turn signals wont. i replaced a relay behind fuse panel and didnt work. is there another relay somewhere in this truck that runs turn signals only and if so where is it. i dont think its a turn signal switch cause ive never seen the contacts in the switch go bad at the same time. but im not an expert so i dunno. any anwers would be of great help thank you
May 16, 2008 at 9:46 AM
KHLOW2008
  • 41,814 POSTS
Hi BENKREPP,
There is no other flasher relay, but the fuse is separate for the turn signal and hazard lights.
I suspect a blown turn signal fuse.
Jun 1, 2008 at 1:24 AM
