I replaced that wire and the coil, But it is still misfiring?
1993 ISUZU
130,150 MILES • 4 CYL • 2WD • MANUAL
FALZ1
This is about a 1993 Rodeo, I got this for free (ha ha) because the air doesn't work,this truck had been sitting for about 1yr. It also needed a new water pump, so I also put on a new timing belt and all the other belts as well. The truck was running ok till it warmed up, then I noticed a spark going from the coil to the top of the engine, so I replaced that wire and the coil, But it is still miss firing. Any ideas.
Thanks,falz
Dec 9, 2007 at 6:42 AM
BMRFIXIT
  • 19,053 POSTS
I would start with new spark plugs here is a guide that can help.
https://www.2carpros.com/articles/how-to-change-spark-plugs
and this guide can help as well
Please go over these guides and get back to us.
Dec 9, 2007 at 7:26 AM
