1992 isuzu rodeo 4x4 5speed 3.1 v6 engine
1992 ISUZU
ADZINDOLET
hello i bought this rodeo and it was cutting out in third and fourth gear or chokeing up im not shure what youd call it.sometimes it also didnt want to start unless you floored it.we put all new plugs wires full filter and distributer and rotur on it and changed the oil.it starts now and gets more power but still messes up the faster you try to go.i was told its not missing.and it runs fine in park but when i try to drive up the road it just chokes or something.its hard to explain.basicly if it was a horse it bucks like crazy.im desperate for help.i was told buy the people i bought it from it only need some carb work but then found out it is a throttle body not even carborated.i spent all my money on this car and its the only one i have i need it to run so i can go to work i have 6 kids to support and no running car.please help
Mar 13, 2007 at 1:25 PM
RGONION
1 Inspect Fuel Filter Clogged or dirty fuel filter
2 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s).
3 Inspect Spark Plug Fouled, damaged or broken spark plug(s).
4 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system.
5 Inspect Fuel Pump Improperly functioning fuel pump or circuits.
6 Inspect Carburetor Float Improperly adjusted/saturated or damaged carburetor float.
7 Inspect Carburetor Needle & Seat Improperly adjusted or worn/malfunctioning needle & seat
8 Inspect Timing Cover Stud Kit - Performance Improperly adjusted or worn/malfunctioning power valve
9 Inspect Choke Pulloff Worn, defective, or faulty choke pulloff(s).
10 Inspect Choke Thermostat Stuck or improperly functioning choke thermostat.
11 Inspect Timing Specification Incorrectly adjusted engine timing.
12 Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor.
13 Inspect Throttle Position Sensor Faulty throttle position sensor or throttle position sensor circuit.
14 Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank.
15 Inspect Air Cleaner Temperature Sensor Damaged or faulty air cleaner temperature sensor or air cleaner temperature sensor circuit.
you can also go to www.autozone.com and check out their trouble shooting on your vehicle
May 9, 2007 at 6:44 PM
NORHAWK
Check exhaust system, might be plugged. Remove oxyen sensor, then take for a drive and see if problem goes away. Make sure sensor removed is before catalytic converter.
May 30, 2007 at 8:25 AM
TAMMY LANE
someone was trying to help me start it and poored gas down the carabertor and stared it on fire we replased the burnt wiers and choke
Jul 2, 2007 at 4:49 PM
TAMMY LANE
[quote:e9d55432e6="tammy lane"]someone was trying to help me start it and poored gas down the carabertor and stared it on fire we replased the burnt wiers and choke[/quote:e9d55432e6]3.6 isuzo rodo back fires and is spitting fire out of carabortor 1992
Jul 2, 2007 at 4:51 PM
CARRIEVE
my 1995 rodeo did the same thing and it was the plugs and wires.
Jul 12, 2007 at 12:51 PM
