1989 Other Isuzu Models Fault in a relay
1989 ISUZU
120,000 MILES • 4 CYL • 2WD • MANUAL
COMET64
The warning lights for both 'charging' and 'low on fuel' in the instrument panel are lit simultaniously.
The engine dies when I release the throttle.
I suspect there is a fault in an electrical component somewhere...
May 12, 2008 at 12:40 AM
2CARPRO JACK
  • 11,533 POSTS
Is the alternator putting out? Need to test it first then the battery and all connections to be sure they are clean and tight and free of corrosion
May 14, 2008 at 2:33 AM
