1985 Other Isuzu Models oil consumtion
1985 ISUZU
180,000 MILES • 4 CYL • 2WD • MANUAL
USAVEDAVE2`
my work truck seems to go through alot of oil. the only thing there is no oil leaking on the ground and it don't blow any blue smoke out of the exhaust pipe. it will go through about 1 - 2 qts 100 miles
May 7, 2008 at 7:56 AM
  • 31,937 POSTS
Hi there,
The oil must be going out the exhaust or on the ground, it cant go anywhere else. If you have no external leaks, check the spark plugs for signs of oil burning,(whitish deposits) the burning may just be minor but constant. Try changing the weight of the oil and keep the services up as oil oil will burn off quicker than fresh.
Mark (mhpautos)
May 7, 2008 at 4:05 PM
