2003 Isuzu NPR engine lamp on
2003 ISUZU NPR
GOVIND
Electrical problem
2003 Isuzu NPR 4 cyl Two Wheel Drive Manual 98000k miles
i have one NPR isuzu truck with 4HL1 ENGINE
THE OD2 SOCKETS HAVE 16 PIN BUT ONLY 8 WIRES ARE CONNECTED
ITHE ENGINE LAMP IS ON I HAVE CAHNGE THE ECU AND THE DCU ,COMMON ARIL PUMP AND ALL SENSORS BUT THE LIGHT DOES NOT GOES OUT
WHAT ACCORDING TO YOU NEED TO BE DONE
RECENTLY THE FUEL FILTER LAMP IS ON ISPITE THE FILTER HAS BEEN DRAINED .
May 15, 2010 at 12:26 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Some OBD11 connectors only have 5 or 6 wires this is not important, what you will have to do is get a scan done and report the codes her for more assistance, start here,
mark (mhpautos)
May 15, 2010 at 3:07 AM
GOVIND
[quote:bbcd2e6472="mhpautos"]Hi there,
mark (mhpautos)[/quote:bbcd2e6472]
CAN YOU SUGGEST ANY GOOD SCAN TOOLS WE CAN USE TO SCAN THIS 4HL1 ENGINE
THANKS
GOVIND
May 15, 2010 at 5:41 AM
  • 31,937 POSTS
I don't know what you have access to there, i use a Snap on scanner, this is a professional unit and it is very expensive, you may be better of contacting a dealer and getting them to do it, as many of the cheaper generic scanners are not that good and don't pick up all codes.
mark (mhpautos)
May 15, 2010 at 6:40 AM
