2001 Isuzu NPR
148,950 MILES • 6 CYL • 2WD • AUTOMATIC
PYRANHA74
2001 Isuzu NPR diesel cab forward.
All lights & signals work fine, but on the dash; the brake, brake booster, abs and battery lights remain on. The heat/air does not blow when turned on, and the radio does not work. The battery seems to be strong and they're not that old (2 months). I had a short in the wiring to the bed but have had that fixed. The smaller 2 prong fuses are all ok. Could it be the alternator or maybe some larger master fuse?
Oct 19, 2010 at 3:03 PM
GARYHOS
Pyranha 74- Did you find a solution to the problem? My truck did the same thing yesterday. Garyhos
Apr 30, 2011 at 9:39 AM
