1990 Isuzu Impulse 3 lights
225,000 MILES • 4 CYL • 2WD • AUTOMATIC
AWOTTLEY
i had the three lights come on replaced the altenator it worked good for a while and then the problem happened again. this time i replaced the battery and the altenator it ran well until i started the air conditioner the lights now com on again . when they com on it seems that there is someting causing a large drain on the system the radio goes off the heater moter goes off the lights dim. reving up the moter somettimes works but sometimes the lights stay on i took the car to autozone to be tested they said the alternator and battery tested good but the lights were not on the. itried to make them come on but of course they would not. i thought the air conditioner was comming on so idisconnected the compeeror i also disconnected the air conditoner cooling fan istill have the problem could the altenator be going bad because when i put the air conditioner on i started to have the problem i am about to buy a new altenator but this will be the fourth one and it is getting expensive
Nov 30, 2008 at 7:40 AM
VBOSS5764
  • 23 POSTS
The problem is the alternator, this is a common problem with some rebuilders, especially the brand Auto-zone carries. The alt checks out fine but in fact it isn't. Get a refund and try Advance or maybe Oreillys.
Be careful when the lights come on the Radiator fan does not work and the car could overheat.
IMO this was a bad design by Isuzu.
Jun 30, 2009 at 2:11 PM
