1998 Isuzu Hombre wont start
161,000 MILES • 4 CYL • 2WD • MANUAL
DADWIARD
My isuzu hombre wont start when it is 40 degrees or lower. someone told me valves need adjusted?
Dec 7, 2009 at 2:05 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 7, 2009 at 8:49 PM
