1996 Isuzu Hombre Starting
96,000 MILES • 4 CYL • 2WD • MANUAL
MEECHYAH
I tried to start my truck, it started for about 5 sec then shut off, and will not start again, it will crank however not start. the fuel pump is from a 4.3L and the truck is a 2.2L is it possible the pump is flooding the engine not allowing it to start. someone said it might be the timeing, I really have no clue, any and all suggestions would be great
Feb 1, 2010 at 3:41 AM
  • 75,988 POSTS
If its starting up before this problem with the 4.3L pump and now it won't start Do below:
Disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard i
Feb 1, 2010 at 4:20 AM
