1996 Isuzu Hombre Fuel pump cutting out
1996 ISUZU HOMBRE
205,000 MILES • 4 CYL • 2WD • MANUAL
RICKYMEARS
  • 5 POSTS
1996 Isuzu Hombre (basically a S-10) runs for a while until it gets good and warm and then the fuel pumps cuts out and the relays in the glovebox overheat. A person can wait until things cool down and then start it right back up again with the same problem. Fuel pump will not cycle when the ignition is turned after the truck dies. When waiting for everything to cool off, you can hear those glove box relays flipping back and forth. Replaced the relays and fuel pump so far.
Apr 13, 2010 at 8:35 AM
RICKYMEARS
  • 5 POSTS
Traced out all or nearly all the wires I can or know too. Any suggestions.
Apr 15, 2010 at 8:54 AM
