1996 Isuzu Hombre engine stalls
LP1015
Engine Mechanical problem
1996 Isuzu Hombre 4 cyl Two Wheel Drive Manual 196 k miles
engine stalls sometimes,fuel filter,fuse, or fuel pump?
where is fuel filter located? is there another fuse box under the hood for me to check?
Apr 7, 2010 at 7:59 AM
RICKYMEARS
  • 5 POSTS
Is your fuel pump cutting out?
I am having a similar problem w/ a '96 Isuzu Hombre. My truck will run but then quits. The relays in the glove box are getting overheating and failing is my guess but I don't know the underlying cause. I have replaced my fuel pump and those relays. When ever it dies on me and I attempt to start it right after wards I can't hear the fuel pump cycle. Is your problem like mine? What have you done?
Thanks.
Apr 13, 2010 at 9:21 AM
