1996 Isuzu Hombre clutch pedal to high
101,656 MILES • 4 CYL • 2WD • MANUAL
MODELS74
I had a new clutch kit installed yesterday. The clutch engages at the very top of the pedal. The old clutch engaged close to the floor board. It was still pretty good but was replaced while the slave cylinder was being replaced. The old clutch had 4 springs while the new one has 6 springs. I double checked all the part stores to verify the correct part number. Also replaced the master cylinder. The truck has a WM2 tranny 5 speed. Any clue as to why the difference in pedal height? It shifts very good but I can't stand the height on the pedal THANKS!!
Jul 31, 2009 at 6:34 AM
DOCFIXIT
  • 18,828 POSTS
Clutch pedal rod is adjustable loosen lock nut turn rod until desired height
Jul 31, 2009 at 6:49 AM
MODELS74
Just looked at it and don't see any adjustment rod. Only the plastic rod from the pedal with a electrical connection going to the master cylinder
Jul 31, 2009 at 7:27 AM
DOCFIXIT
  • 18,828 POSTS
You have cruise control?
Jul 31, 2009 at 7:31 AM
