1996 Isuzu Bighorn hello
ROGER007
  • 38 POSTS
Engine Performance problem
1996 Isuzu Bighorn 4 cyl Four Wheel Drive Automatic
what is the problem of my isuzu bighorn 3.1D intercooler turbo the engine thus not run?
May 30, 2010 at 2:27 PM
  • 31,937 POSTS
Hi there,
Are you getting any fuel delivery at the injectors, back off a pipe union (not all the way) and crank over, you should get fuel spilling from the loose union, and more than a dribble.
mark (mhpautos)
May 30, 2010 at 7:37 PM
ROGER007
  • 38 POSTS
the engine run now..but if the engine is heat he doesn't run anymore but if the engine is cold the engine is run..what is the problem of my car?
May 31, 2010 at 11:44 PM
  • 31,937 POSTS
is the engine over heating or is it cutting out at normal operation temp?
mark (mhpautos)
Jun 1, 2010 at 1:13 AM
ROGER007
  • 38 POSTS
it doesn't overheat,and we dont detach any wiring
Jun 1, 2010 at 1:19 PM
  • 31,937 POSTS
Check that the fuel cut of solenoid is getting power, this should be a solenoid on the injection pump, look here.
mark (mhpautos)
Jun 1, 2010 at 1:54 PM
ROGER007
  • 38 POSTS
where i can find that solenoid?
Jun 1, 2010 at 2:07 PM
ROGER007
  • 38 POSTS
thiis isuzu bighorn is controlled by ECM
Jun 1, 2010 at 2:09 PM
ROGER007
  • 38 POSTS
what is the problem if the engine hot but the engine didn't start i change the fuel pump...what is the problem of my car?
Jun 2, 2010 at 6:09 PM
