1995 Isuzu Bighorn
ROGER007
  • 38 POSTS
Electrical problem
1995 Isuzu Bighorn 4 cyl Four Wheel Drive Automatic
how can i know if the crankshaft sensor is already busted?and what are the sign?help me please!!!!
Jun 4, 2010 at 1:10 AM
  • 31,937 POSTS
If there is a problem with the crank shaft sensor, a scan will show this up as a fault code, if a crank sensor is faulty the ECU will not get a primary crankshaft reference and the engine will not run. check this first.
mark (mhpautos)
Jun 4, 2010 at 1:15 AM
ROGER007
  • 38 POSTS
i check the crankshaft sensor it's ok.the problem is when the engine is cold the engine start.ofter and hour i turn the key off and then i start againthe engine does not start anymore.what is the solution of my 4jg2 3.1d engine
Jun 6, 2010 at 11:29 AM
ROGER007
  • 38 POSTS
i check the crankshaft sensor it's ok.the problem is when the engine is cold the engine start.ofter and hour i turn the key off and then i start again the engine does not start anymore.what is the sulution of my 4jg2 3.1d engine
Jun 6, 2010 at 12:54 PM
