2008 Isuzu Ascender engine knocking
2008 ISUZU ASCENDER
53,000 MILES • 6 CYL • 2WD • AUTOMATIC
RCADENA7
The engine started knocking which sounds like a tappet. It also started missing and the rpms dropped on idle. This morning it will crank but could not start it.
It is less then two years old, is this possible?
Oct 18, 2010 at 4:26 AM
KHLOW2008
  • 41,814 POSTS
Hi RCadena7,
Thank you for the donation.
When the knocking started, did you take note of the temperature gauge reading?
Check the coolant level in radiator.
Check engine oil level.
At bottom of post there is a " First Things To Check " link where you can get some idea what to check when engine could not be started.
Oct 19, 2010 at 2:30 AM
RCADENA7
Temperature was normal, oil pressure normal, I did stop and check the oil level and it was fine. In the owners manual it said to continue at a slower rate so long as the icon of the engine did not start flashing. I reduced my speed to 30 miles however, engine was fluttering and i though it was going to stop. I raise the speed limit to 40 and drove home.
Oct 19, 2010 at 10:21 AM
KHLOW2008
  • 41,814 POSTS
Did you perform the test as outlined in the " First things To Check " link?
You need to determine what is missing causing the non starting, fule, mechanical or ignition fault.
Oct 20, 2010 at 12:14 AM
