2006 Isuzu Ascender Fuel level float
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
CAST
My instrument panel level reads empty even after I fill up and buzzer sounds. The indicator will steadly climb to full then back to empty. Which makes my check engine light comes on.
I think this is what it is or am I wrong?
How do I change out the float level?
Feb 6, 2009 at 7:13 AM
BRIAN 1
  • 1,030 POSTS
to change the level sensor you have to drop the gas tank and remove the fuel sending unit and the level sensor is on the side of the unit.it can be serviced seperatly.post back with any other questions.
Feb 6, 2009 at 8:56 AM
