2006 Isuzu Ascender
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
CBOSS
No brake light on rt or lt tail light. I do have on the rear door. I have checked all fuses under hood and under rear seat. also checked the bulbs. im at a loss/ please help. Thanks
Nov 28, 2008 at 5:47 AM
  • 75,988 POSTS
Info
Do you have the R/Turn signal ?
Nov 28, 2008 at 6:10 AM
CBOSS
[quote:2841b44d06="rasmataz"]Info
Do you have the R/Turn signal ?[/quote:2841b44d06] Yes all other lights work. rt turn also
Nov 28, 2008 at 6:20 AM
  • 75,988 POSTS
No brake light on right side and left tail light is this correct?
Nov 28, 2008 at 6:24 AM
CBOSS
[quote:8d35f13e2c="rasmataz"]No brake light on rt or lt tail light.
No brake light on right side and left tail light is this correct?[/quote:8d35f13e2c]
That correct, but i do have on the rear door.
Nov 28, 2008 at 6:27 AM
  • 75,988 POSTS
Double check the trailer wiring connector for corrosion if okay-the wires between this 2 circuit could open within the wiring harness. With no electrical background this one can be a nightmare for DIY-I strongly recommend you bring it in.
https://images.2carpros.com/forum/automotive_pictures/12900_ascender_1.jpg
Nov 28, 2008 at 6:44 AM
CBOSS
Thanks I'll check it out.
Nov 28, 2008 at 7:18 AM
